Hello,
I have a DJ box i take out to gigs, but I dont always set this up at home. Will it let me install onto my pc too or will the other one get blocked? Can be a pain sometimes setting it back up to take it back down the next day. Sometimes i just wanna do a quick broadcast on internet radio.
geposted Fri 25 Aug 06 @ 2:23 pm
You can install it on two or more PC's - one won't get blocked even if both are connected to the internet.
I think you are actually allowed to do this as long as both machines are for your own use.
However i'm not 100% sure so you may want an 'official' answer from VDJ. (try browsing through previous posts i'm sure its been mentioned in the past)
geposted Fri 25 Aug 06 @ 3:53 pm
i suspected so but didnt wanna balls up my DJ box.
geposted Fri 25 Aug 06 @ 4:20 pm
You can install it on 2 machines, not more, read EULA.txt in your VDJ folder.
geposted Fri 25 Aug 06 @ 4:41 pm
Wicked, thanks Alf!!
geposted Fri 25 Aug 06 @ 5:00 pm
