Hi, i have to make a recording, to burna CD, i press the burn the CD, so it records in different tracks when the crossfader hits the other side, and so i go to burn the CD, the file comes out as a .CUE File, my Nero wont allow me to burn those files, how can i change it so it records in a different format, that allows it to be burnt with Nero, or what do i have to do so it burns.....
geposted Fri 25 Aug 06 @ 5:48 pm
I can suggest you record to a file, then use a wave editor to cut the tracks up. This will prob leave silence when the tracks change though :/
If it works, then burn the wave / mp3 files to the disk using nero
geposted Fri 25 Aug 06 @ 6:05 pm
ok thanxx, anyqway i have already found out how to do it perfectly. without using Nero
geposted Thu 14 Sep 06 @ 8:58 am
