Topic: the 3 effects of VDJ
before 3 effects could contemporarily be activated.
I wanted to know if 3 effects can now be activated contemporarily with keyboard; if yes, as does he do????
geposted Fri 25 Aug 06 @ 8:17 pm
dj-in-norway wrote :
with VDJ4 is not 3, but AS MANY as you like, UNLIMITED ;)
how does it do him to activate 3 effects with 3 different buttons of the keyboard (contemporarily)??
you have not perhaps understood me.
We make an example:
we suppose that I want to associate to the letter Q the the effect "Flanger" to the letter A the effect "Beatbox" and to the letter Z the effect "Delay"
How does he do???
Now, while it is playing the disk I want to change the effect "Flanger" with the effect "Brake": how does he do???
It serves me change in real time the effects
ok;) Give me 5 minutes.. I'll make a short guide with pictures for you
I have tried:
however an effect is activated for only time with shortcuts (it is not possible to contemporarily use all the 3 effects)
If I press Q is activated the first effect, if then I press A is activated the second effect and is disarmed the first one, if then I press Z is activated the third effect and is disarmed the second!!!!
It is this my problem
hmm...
You are absolutely right about that...
You can map as many fx as you want to keyboard, but only use one at a time.
If you want to use serveral effects at the same time, it can only be done in skin.
Seems we need a new keyboard shortcut for v.4.1 ;) I'll mention it for Dev Team
You tell the developers team of this problem because for me it is important to contemporarily activate more effects with shortcuts (such function was present in the version 3.4)
Thanks dj-in-norway
I agree with sischo, I like using 2 or 3 effects in same time and activate it in same time ... so it would be great if it will be corrected in the 4.1, thx
Dev Team is aware that people want this back, and will probably be available in 4.1 :)
