HI all
After install 4.0 all my mp3 author saya
author + :DDB Disc ID or a number like this : 170E0902
the. The VirtualDJ Database.xml was backup.
I have 3.4 and 4.0 installed what can i try to do?
I also keep getting this on my desktop plug_in.ini
thanks
thanks
geposted Sat 26 Aug 06 @ 3:15 pm
can anyone help with this
geposted Sat 26 Aug 06 @ 8:35 pm
I've actually got no clue...
Other than that you have enabled IDtag READ, and that this information comes from your tags?
geposted Sat 26 Aug 06 @ 8:37 pm
IDtag READ and write is disabled. I use Tag&Rename IDtag V ID3V2 for all my tags and now they all are reading bad and when I try to fix it and reopen VDJ they go back bad.
geposted Sat 26 Aug 06 @ 8:59 pm
I fix it I had to delete my VirtualDJ Database.xml and do it all over again can of cool to run 3.4 and 4.0 together
geposted Sat 26 Aug 06 @ 10:53 pm
