Hey peoples,
Is there any way to broadcast and record a performance? I understand that inside VDJ I can only do one of the other... so is there another work around?
Thanks
Thanks
geposted Sat 26 Aug 06 @ 8:15 pm
you could always broadcast using VDJ and record using another program running in the background.. just setup the settings in that program or windows mixer to record your own soundcard's stereo mix or something :)
geposted Sat 26 Aug 06 @ 8:22 pm
I thought about that. I could use SOund Forge, but it's a rather memory intensive application. Any small apps that can record in WAV or MP3 format? (sugestions?)
geposted Sat 26 Aug 06 @ 8:26 pm
smallest, least CPU hungry : Windows sound recorder ;)
geposted Sat 26 Aug 06 @ 8:29 pm
Thanks, but Windows Sound Recorder only works up to 60 seconds. There are a few work arounds for this app, but none that are or of real value.
Thanks though.
... and DJ Norway, hope you dont work all weekends.
Peace,
James Rose
New York City
Thanks though.
Peace,
James Rose
New York City
geposted Sat 26 Aug 06 @ 8:43 pm
I'm leaving for a gig right now, but will try to take sunday off everything ;) hehe
Did not know that Windows recorder only allows 60s .. what a shame! hehe..
But there are SOOOOOO many free recorder shareware that will record your main sound from your soundcard... ;)
Some are pretty small cute apps, that dont take much memory
geposted Sat 26 Aug 06 @ 8:45 pm
Hope your gig goes/went well
I found this little recording app
http://www.fridgesoft.de/downloads.php (top item)
here is the direct url
http://www.fridgesoft.de/downloads.php?dl=hdogg
Hope this helps others.
Peace,
James Rose
New York City
Peace,
James Rose
New York City
geposted Sat 26 Aug 06 @ 9:08 pm
Check out the free program Audacity from www.audacity.com
It's awsome!! I use it all the time to record.
geposted Sun 27 Aug 06 @ 3:46 am
