Hi,
I've noticed that when you use the clone_deck action, the actual key state is not cloned. Is that intended? Shouldn't the clone_deck, clone the whole deck, key included?
Pier
Pier
geposted Mon 28 Aug 06 @ 3:55 pm
good suggestion, but because the key enables automatically the master tempo/key lock i think its a litle unsafe now, because some systems dont work well with the advanced master tempo on both decks activated. (no problem with the fast algorithm though)
So for now better to do it manually if you wish.
geposted Mon 28 Aug 06 @ 4:35 pm
Tnanks!
geposted Mon 28 Aug 06 @ 5:10 pm
