I am trying to find out some info about Numark iCDX
1 Will I still need a sound card with it? Or the you use the audio out on the iCDX
2 Can you use just one like the xp10?
3 Will you need two open usb 2.0 or can you go from iCDX to iCDX
geposted Tue 29 Aug 06 @ 9:19 pm
1) you need a sound card
2) yes
3) they work independently i think, meaning you need 2 usb. (why is this a problem?)
2) yes
geposted Tue 29 Aug 06 @ 9:25 pm
usb ports are not a real problem just trying to find out more about the iCDX
will it play cds from VDJ or it on line out like I side I am still trying to find
out more about this new toy and the type of outputs it has.
geposted Tue 29 Aug 06 @ 9:29 pm
Not sure about cd's playing through vdj via usb, but im guessing you will probably need to connect it via rca to your computer and use the bypass to play the cd (which is pretty pointless anyway cause you can just put the cd in your computer and load a track directly onto vdj and control it like normal).
It will have normal rca outputs as well as digital spdif. There might be a syncro relay port on it, like the original CDX.
Unfortunately numark has no technical details on their website on their products, so google is a good source to start with.
geposted Tue 29 Aug 06 @ 9:39 pm
thanks again for the info for $700 i need some more info from Numark I like what I know about it but some more info would be good or a good picture of the back would work to
geposted Tue 29 Aug 06 @ 9:51 pm
Unfortunatley, seeing as it hasnt been released yet, public pictures have been few (found 3 on google). Maybe once its released we will see more.
geposted Tue 29 Aug 06 @ 9:55 pm
Some sexy dj software working with the far too sexy iCDX;))
geposted Tue 29 Aug 06 @ 9:59 pm
can you show a picture of the back
some one has all the toys
geposted Tue 29 Aug 06 @ 10:02 pm
rather WISH they had ;) I dont have the iCDX (yet... )
Picture is from DJ Expo in AC,USA
geposted Tue 29 Aug 06 @ 10:11 pm
why there is nobody that took some more photos of the hotest hardware which is comming? :)
I would really like to know some more information about it. However, it is not released yet.
geposted Tue 29 Aug 06 @ 10:32 pm
They will be the perfect match to my nuo4 :)
geposted Wed 30 Aug 06 @ 12:54 am
From what I've read so far the iCDX is the following:
DVD/CD MP3 player (Will play MP3s from CD or DVD)
Audio CD Deck
External controller
Which makes it a replacement for my Pioneer CDJ1000 right NOW.
Audio CD Deck
External controller
geposted Wed 30 Aug 06 @ 1:04 am
yupp... all of that
PLUS:
- can play directly from any external usb harddrive, memory stick or even ipods;)
Perfect mate for VDJ, and perfect backup
Also, first reviews gives it a high tumb up for having good scratch jog etc
http://www.12am.com.au/?id=1446
PLUS:
geposted Wed 30 Aug 06 @ 1:14 am
- USB port for connecting mass storage class iPods, hard drives and memory sticks
- USB port for interfacing with Virtual DJ (native supported in 4.0)
- Illuminated slot-load drive with support for CD/CD-RW/DATA DVD
- Touch-sensitive scratch wheel
- Large, backlit LCD display for system information including MP3 ID tag information
- Integrated DSP effects include Phaser, Filter, Flanger, Echo and more
- Key Lock (± 100%)
- Large pitch slider for controlling music playback speed
- Automatic BPM counter
- Hot starts, seamless looping, scratching with sampling, Full support for MP3 playback
- Digital outputs
I'm in love....
geposted Wed 30 Aug 06 @ 1:28 am
thanks for all the info I realy do think I want two, so off to work I must go to come up with
$1400 to pay for this
geposted Wed 30 Aug 06 @ 2:28 am
The only problem is that you will need another sound card to work with VDJ. This is the only thing that i mist on it. It could have small sound card... Ok i will use my maya for it :)
geposted Wed 30 Aug 06 @ 10:12 am
