See this link!
I am thinking about getting this microphone preamplifier for the Mk2. It's quite low priced and someone recommend me getting one because the microphone will sound much better and louder. I have a Philips vocal microphone which at present is very low volume even when maxed.
I need some advice. Is this is a good product? What do I need to check?
Thanks
Thanks
geposted Tue 29 Aug 06 @ 10:32 pm
This page is in German, but you can probably see from the picture? Is this what I woud need?
http://www.amazon.de/gp/product/B000F45XC6/028-2701085-6666944?v=glance&n=562066&m=A3JWKAKR8XB7XF
I can't see any output options. You plug the mic in and then what?
Are the output connections on the back?
geposted Wed 30 Aug 06 @ 5:39 pm
