Let me copy/paste what i wrote in another thread, about how you can use the main effect slot as in pioneer cdj100/200 decks: select/activate and adjust...
(Just to see the bright side of the moon...)
I'll give you one good reason why its more powerful now.
One main slot, YES, that means one fx at the time, one but POWERFUL...
You can now assign up to 5 midi sliders and also buttons (keyboard or midi) to control the parameters of the main slot.
Then you can create direct access buttons, (keyboard or midi) to select and acivate the desired effect in the main slot.
At the end you can have unlimited buttons to directly call and activate effects and use the 5 midi sliders and buttons to edit them LIVE....
Isn't the same but most powerfull than the cdj100/200 decks ?
Select an effect, adjust it... so simple.
This function was very limited in 3.4
As for more than one effect at the time, only with certain effects like an eq or limiter you really need this. For these effects indeed there is a limitation, but you can use the effect page.
Personally (and that's what i advised) i'd like a "per effect" setting to choose the "important" effects to stay on.
Just think about the mess when some effects remain enabled when you switch effects as there is only one effect slot now.
geposted Wed 30 Aug 06 @ 12:24 am
