why dudes where the
timescratch ( now when i adjest the pitch the sound change... come on .. the old one in the vdj 3 was great why u had removed it )
and what about the atommix effects why they don't work on VDJ4...i was working on vdj3...
there are many other bugs in the vdj 4 i will tell u about them later.. but plz work on this .. cuz they r important....
geposted Thu 31 Aug 06 @ 11:10 pm
Effects are not v4 ready (all of them), but they will be soon. And you have to enable keylock that your music won't change sound when changing pitch.
It is all about settings. v4 works well ;)
btw what are other problems that you have?
geposted Thu 31 Aug 06 @ 11:30 pm
ok 10x about that.. . now all what i have to do is to wait for the new mix station skin :)
geposted Fri 01 Sep 06 @ 12:24 am
yeah, i am waiting 4 it too :D it is very good skin and looks PRO ;)
geposted Fri 01 Sep 06 @ 12:37 am
Timestretch is now called "Keylock" and can be found on the main page as a little lock.
geposted Fri 15 Sep 06 @ 1:46 pm
Keylock only works like master tempo (timestrech) when u lock it a 0% pitch
geposted Fri 15 Sep 06 @ 2:48 pm
Yes and No....
The old Master_tempo still exist, along with the new keylock.
But keylock is just a "type" of master tempo/time stretch and uses the same algorithm.
If you like the "old way" ... like i do, just use master_tempo instead in your shortcuts, skins etc.
geposted Sat 16 Sep 06 @ 3:39 am
