i have dm2s and i have virtual dj and i got that DM2MIDI now if some one would tell me how to program it would be great
geposted Fri 01 Sep 06 @ 12:53 am
think you need VDJ full version for good support for that;) Specially VDJ4's new midi support
But look inside VDJ, at keyboard shortcuts tab.
And make your midi shortcuts
Be sure you have midi enabled in controller tab too
Hope that helps ;)
Hope that helps ;)
geposted Fri 01 Sep 06 @ 12:55 am
thanks k but how do i make thoes midi shortcuts i basicly want the jog wheels to scrach and the cross fader and 4 buttons for effects or samples
geposted Fri 01 Sep 06 @ 12:59 am
everything except the scratch will be easy
1) enable midi as controller (in controller tab inside VDJ)
2) go to keyboard shortcuts tab, and browse for a shortcut/function you would like to map
3) choose the values for that shortcut, and press the button on your midi device to teach VDJ what button you want to use
thats basically it
The scratch can be a bit tricky, you might not have luck there, but you can try.
In VDJ4 its easier for scratch mappings
thats basically it
geposted Fri 01 Sep 06 @ 1:02 am
k i might go bye it cuz i'v lost ym product code so
geposted Fri 01 Sep 06 @ 1:05 am
no worries, we'll help you get to know the program...
Just ask things you need to know:)
And hopefully you can save up for your own licence one day;)
geposted Fri 01 Sep 06 @ 1:07 am
ya i'm doing play right so where do i find the valu?
geposted Fri 01 Sep 06 @ 1:13 am
Look at the image;)
Here I've choosen the keyboard key "T" for my shortcut
You need to press a button on the midi device instead;)
geposted Fri 01 Sep 06 @ 1:16 am
nothing happens
why is that
why is that
geposted Fri 01 Sep 06 @ 1:20 am
well, if it doesnt work, blame the crack
Cracked version often are cracked demos, so features are DISABLED.
Sorry
Sorry
geposted Fri 01 Sep 06 @ 1:23 am
Demo's should come fully loaded so that the crack versions work better...Not
geposted Fri 01 Sep 06 @ 1:40 am
its not cracked do u have to use dm2 to midi cuz i have nodiea hwo to use that
geposted Fri 01 Sep 06 @ 1:46 am
No only demos that are cracked are bug free... full releases contain all the bugs for licensed users to complain about and the crack heads live in harmony.
geposted Fri 01 Sep 06 @ 1:48 am
man i just wana sue this stupid dm2 so complicated dose any one have like the short cuts dun i don't understand this
geposted Fri 01 Sep 06 @ 1:50 am
no one can just help me liek wow great support my dm2 dosn't work when u sue virtual dj like no lights go on unless i have the dm2 program open or dm2 to midi
geposted Fri 01 Sep 06 @ 2:01 am
Well I did help ;)
Try again, do it in these steps:
1) ENABLE MIDI
2) MAKE SHORTCUTS
geposted Fri 01 Sep 06 @ 2:04 am
Is your DM2 even being recognized by windows?
geposted Fri 01 Sep 06 @ 2:05 am
dj-in-norway -- helped you as far as possible and since your using the demo version - as norway said it is limited in capabilities - i.e. DEMO.
However, go to the Config.. Go to the Remote control tab... check the MIDI control check box... Click config and start configuring your dm2. Beyond that... hopefully a dm2 using will come along and help you further.
geposted Fri 01 Sep 06 @ 2:08 am
its not demo lol i just can't ifnd my code ya it is by windows cuz i can use it with other programs liek mix vibs but not on v dj why is that no lights turn on do u need dm2 to midi
geposted Fri 01 Sep 06 @ 2:17 am
Not talking about your dm2 being a demo... talking about the fact you are using the DEMO of Virtual DJ. but again to answer your question... yes maybe you need the dm2 to midi in order to send midi signals to VDJ.
geposted Fri 01 Sep 06 @ 2:21 am
