1) If buying 4.0 Pro edition is a download, is there a 4.0 User Guide with it? I saw "Use Guide" at the top, but it was for Home Edition 2006.
2) I saw the mp3 download for the timecoded CD- After purchasing I would just have to download that and burn to cd and when I put it in the CD players it plays accurate with VDJ after all is hooked up correctly?
Thanks for any responses,
B
B
geposted Fri 01 Sep 06 @ 8:23 am
The guide isn't available yet for 4.0
Yes , just burn the timecode mp3 to cd and it will work correctly.
Hope to have you join the crew soon :)
geposted Fri 01 Sep 06 @ 8:49 am
Current user guide is written for VDJ 3, but the v4 user guide will in no doubt be updated. However, in my perspective, the user guide is very valuable since the topics are still the same - it is not a totally new version. I find it still usefull and implements the functions in V4. The forum, I must add, is probably the best "User guide".
The use of timecoded CD's/Vinyls works perfectly fine in PRO version! Good luck!
geposted Fri 01 Sep 06 @ 8:53 am
Thank you.
geposted Fri 01 Sep 06 @ 4:15 pm
