1st. WHAT ABOUT IF WITH THE MULTI INSTANT SKIN OPTION MAKE THE VIRTUALDJ RESTORE FROM A CRASH FASTER? WHAT I MEAN IS, IF THE PROGRAM CRASH WHEN YOU ARE MIXING, THE CRASHGUARD WINDOW APPEAR AND ASK YOU TO RESTORE VDJ. THE MUSIC STILL PLAYING ON THE BACKGROUND (WELL, THIS IS WHAT HAPPEN TO MY VDJ. WHEN THE CRASHGUARD APPEAR, THE MUSIC STILL PLAYING BUT I DON'T HAVE THE ABILITY TO PRESS A BUTTON, LOAD ANOTHER SONG
OR MAKE ANYTHING ELSE WITH VDJ). SO, WHEN VDJ CRASHING, ANOTHER VDJ OPEN PARALLEL WITH THE CRASHGUARD WINDOW AND WHEN THE 2nd VDJ OPEN NORMALLY THEN YOU CAN PRESS THE OK BUTTON OF THE CRASHGUARD AND THE MUSIC IT WILL CONTINUE FROM THE POSITION OF THE 1st CRASHING VDJ. I BELIEVE THIS OPTION CAN MAKE VDJ TO RESTORE FASTER. IF NOT CONTINUESLY, MAYBE WITH LESS THAN 3 SECONDS GAP TO THE MUSIC.
IS POSSIBLE TO SEE SOMETHING LIKE THIS ON THE NEXT UPDATES?
AND 2nd. IT WOULD BE GREAT IF I COULD CHANGE IN THE CENTRAL WINDOW WITH THE MUSIC FILES THE ORDER OF THE TITLE AND THE ARTIST. FOR EXAMPLE, MOVE THE ARTIST SECTION TO TITLE SECTION OR, THE BPM SECTION TO THE LENGTH SECTION. I HOPE TO SEE THAT IN THE VDJ 4.1.
P.S.
WELL, AFTER A BETTER LOOK, I'VE FOUND THE PICTURE SLIDESHOW ON THE VIDEO EFFECT TAB.
P.S.
geposted Fri 01 Sep 06 @ 3:37 pm
not with caps pleaseeeeeee :)
geposted Fri 01 Sep 06 @ 5:58 pm
You can do it with this Registry tool.
geposted Sat 02 Sep 06 @ 7:33 am
THANKS FOR THE HELP DJ-ALF.
REGISTRY TOOL REALLY DONE THE JOB. BUT I THINK IT'S GONNA BE BETTER IF I CAN CHANGE THE ORDER WITH THE MOUSE DRAGGING.
ANYWAY, I'VE DONE WHAT I WAS WANT, WITH THE REGISTRY TOOL.
THANKS AGAIN.
THANKS AGAIN.
geposted Sat 02 Sep 06 @ 5:40 pm
No problem, that's why we are here ;)
Have a good mix!
Have a good mix!
geposted Sat 02 Sep 06 @ 7:10 pm
