I Just started using VDJ 3.4 a couple of days ago. Is it possible to use the crossfader on a Numark mixer (came with the fusion 222 pkg.)? The only way I've been able to get the mixer (but not crossfader) to work is in the config. panel is to select the two soundcard option connect to home stereo and headphone) I have a external creative soundblaster usb and sigma tel internal card (dell) .The back of the external is labeled in-front-rear-subwoofer.Using mini-jack to rca adapter, then running lines into aux.1 &2 in mixer. Back of mixer is going from left to right, player a -player b- record-aux1-phono1-aux2-phone2. Am I using wrong adapters? Kind of long explanation, but tried to be as specicific as I could to get some help. Thanks.
geposted Sat 02 Sep 06 @ 6:27 pm
Connect your Sound Blaster and than:
Sound setup:
If you using mixer:
Outputs:External Mixer
Sound Card(s):4.1
Front output is left deck, Rear output is right deck.
If you don't use mixer than:
Outputs:Headphones
Sound Card(s):4.1
Front output is Master out, Rear out is your headphones.
You connect rca's to the line inputs, not the phone.
Sound setup:
If you using mixer:
Sound Card(s):4.1
Outputs:Headphones
Sound Card(s):4.1
geposted Sat 02 Sep 06 @ 7:00 pm
Thanks DJ-Alf, Had to return the sound card because the rear line wasn't working. Used your suggestions and crossfader on mixer now works right. Problem now is the headphones don't prelisten, they follow the crossfader. Using the 4.1 one sound card like you said and with the 7.1 unchecked. Thanks again
geposted Mon 04 Sep 06 @ 8:31 pm
Is your headphone plugged into the mixer?
geposted Mon 04 Sep 06 @ 9:53 pm
Yea, It's plugged into the mixer outlet. Tried the split and blend button but still coming out of right side and music moves with the crossfader Thanks
geposted Mon 04 Sep 06 @ 11:34 pm
No problem, glad you found the solution ;)
geposted Tue 05 Sep 06 @ 3:55 am
