Forum: Music discussion
Topic: CHOPPED AND SCREWED
DOES ANYONE KNO IF U CAN CHOP AND SCREW MUSIC AND HOW TO DO IT I NEED A LIL HELP I JUS STARTED
geposted Sun 03 Sep 06 @ 8:12 pm
I chop and screw music using VDJ, first go to config, then under fame settings tab locate "master tempo" or "time stretch" , both the same, disable it, now click ok , bring the pitch slider upwards to maybe 18 or 20 % whatever sounds better and the easy part is done, chopping it is hard , dont really know what to say for that ...
well about the chopping one of da things u gotta do is feel the beat and go w/it so u can find da right time to chopp it.
press on the num pad 3 and the 1 at the right time to chop
yea using the skip 1 beat is good for chops but it doesnt always work
I NEED TO GET MORE SOUND FX WHERE CAN I GO
mrdragudown for security reasons your message won't appear until a moderator has reviewed it.
