i have a problem im not able to listen to both of the decks in my headphones i only listen to the one playin,i dont know why?with 3.4 i never had this problem
geposted Tue 05 Sep 06 @ 5:46 am
hey...
please check which jack the speakers are connected to ...
if your master out (see in the sound config) is channel 1/2, and the headphones are 3/4, make sure that the speakers are in the correct channel jack..
if the speakers plugged into the headphone channel, the headphone out of the console will not work...
hope that solves the problem..
cheers
DJ Rudra
cheers
DJ Rudra
geposted Tue 05 Sep 06 @ 5:28 pm
Did that help you?
geposted Wed 06 Sep 06 @ 6:53 am
thanks that fixed the problem
geposted Thu 07 Sep 06 @ 1:56 am
