Forum: Wishes and new features
Topic: Soundcard configuration presets/profiles
Proposal for a feature enhancement:
I'm using VirtualDJ 2 in different environments, for example creating mixes for my own pleasure, broadcasting in my flat and so on. The soundcard configuration has to be changed for each project. The possibility to define some configuration presets/profiles for the soundcard configuration tab in VDJ2 (the enhanced settings tab) would be highly appreciated.
What do you think about it?
Regards,
Doc Stega
geposted Tue 06 Jul 04 @ 7:03 pm
You can do that with a multi-user option lets different users keeps their own settings (with Windows)
Coyote
geposted Tue 06 Jul 04 @ 11:59 pm
claxPRO InfinityMember since 2004
I'm with you Doc Stega it's a good idea.
geposted Wed 07 Jul 04 @ 1:11 pm
@coyote: ok, thanks for the hint, but it's not very user friendly :-)
@clax: Thanks for the support ;-) The goal is simple: To make VDJ the best product of its kind...
Doc Stega
geposted Wed 07 Jul 04 @ 6:20 pm
