If you plug your mixer power lead into the same extension lead as your pc power lead and then switch your mixer on, is there a chance of blowing a component in the PC. I had VDJ running fine and then i made some mods to my djbox and had the both plugged into the same ext lead, now when i put VDJ on it says sound card driver error. I run the diagnostics (soundblaster 5.1) and it says hadware not found!
I have a gig tomorrow what do you suggest?
Thanks
Craig
Thanks
Craig
geposted Fri 08 Sep 06 @ 11:05 pm
I don't think so. You can plug them in the same extension without problems. Your sound card is having a problem, try reinstalling drivers or change it's place in the PCI slot (if it's not USB). Check in Device Manager is your PC seeing your SB at all.
geposted Sat 09 Sep 06 @ 7:35 am
Thanks DJ-Alf.
I managed to take the top of my pc and wiggle the soundcard and it worked. I done a gig and it was absolutely fine. My heart was pouning when I wrote my thread. I hope it doesn't happen when i'm gigging!!!! I will try and change PCI slots maybe that'll be better. Thanks again.
geposted Mon 11 Sep 06 @ 2:58 pm
