I thought I read that 4.O Pro has this feature when mixing video and audio...
When you mix from video to an audio track, the program will go automatically to send out a visual or a grahic of choice to the crowd.
is this exactly true?
No one has mentioned or talked about this and I wanted to know all about this feature.
Thanks!
Thanks!
geposted Mon 11 Sep 06 @ 4:27 am
May not be in the demo version, but for pro, on the video settings page, under "When No Video Present Use This Plugin". Just type slideshow or sonique in there and make sure the pugin is set up the way you want it to appear. 4.1 will proberly have this text box replased with a drop down list.
geposted Mon 11 Sep 06 @ 5:16 am
THanks.
geposted Mon 11 Sep 06 @ 5:56 am
