Congratulation to DJ vnz
I use the internal mixer and video for my club shows, and struggled with having to change VDJ4 skins back and forth between internal mixer and full video.
You have saved me from going insane!!!!!!!
If you have wide screen, down load DJ VNZ’s skin.
http://www.virtualdj.com/addons/skin.html?id=2213/
geposted Thu 14 Sep 06 @ 4:25 pm
Im glad I could help.
Thanks
Thanks
geposted Fri 15 Sep 06 @ 4:22 am
That is a really nice skin,I like the layout with a larger crossfader and three video windows.
Nice job,any chance you could do it in a 1440 by 900 ?
P@40
P@40
geposted Fri 15 Sep 06 @ 4:44 am
Yeah, big up VNZ. I'm done searching for a skin. Now I can play more. I did a couple of tweaks in the xml & bmp to fit my likes. Overall good job.
geposted Fri 15 Sep 06 @ 5:42 pm
Could anyone using this skin verify if the text messaging works or not,it does not on my computer but does with other skins.I'm not sure if it is the skin or my computer,thanks P@40
geposted Fri 20 Oct 06 @ 9:27 pm
Yes, I should have given you props earlier, let me join the bandwagon by saying GREAT skin.
If you ever do an update can I suggest a separate video mix panel which can be hidden for those who just do music.
I wish I had talent like you skinners.
geposted Sat 21 Oct 06 @ 1:49 am
OHHH YEAAA man its GREATTT
geposted Sat 21 Oct 06 @ 12:42 pm
