Forum: VirtualDJ Skins
Topic: Help with xml changes
Ok, I have the skin by Takeda but I want to make a change.
I open an editor and I type the command I want.
What I want to do is take vmix but make the sync like version 4.0 so that when I click sync it does a beat match to the CBG or when I right click on it it matches and plays to the wave form (like the old sync_nocbg command)
I look at new 4.0 skins and copy the same syntax minus the x/y positions and insert. When i save and try to use...the skin just defaults back to old behavior.
The only way I have been able to achieve this is to just assign a kb shortcut i.e. x=sync_nocbg
I can't seem to get this skin to emulate the new sync behaviors..suggestions?
I replaced:
<button pannel="1" action="sync" chan="1">
with this
<button action="sync" chan="1" rightclick="auto">
and nothing changes
I have even added the " rightclick="auto" " to the origional line and no change happens.
Help?
geposted Thu 14 Sep 06 @ 11:13 pm
Try to replace it with:
<button pannel="1" action=[color=red]"sync_nocbg"[color=black] chan="1" rightclick="auto">
I understand, but I was trying to emulate the wat the 4.0 sync works the sync button.
Sorry. I thought you meant the other way around. Anyway, I dont know why that should not work. The new Sync line ups the cbg's. Make sure thats not the case.
