How to I go about adding more than one pic to my blog(s)? Everytime I upload a pic, it replaces the previous one next to my name. Do I need to use html in the body of the blog?
geposted Fri 15 Sep 06 @ 11:59 pm
If you scroll down, i think you'll see plus sign written images. If you click it, all the images you uploaded should be there.
geposted Sat 16 Sep 06 @ 12:11 am
I tried to drag a pic onto the blog, but all I got was the pic's filename.
geposted Sat 16 Sep 06 @ 2:30 am
Easy as that. Use the list of available BB Codes (under every post/blog you are currently writting/editing) for more layout functions. HTML tags DO NOT work.
Regards.
geposted Sat 16 Sep 06 @ 9:49 am
Thanks, erxon. Now, I just need to get the images small enough to not be overwhelming. I had them down to between 230kb to 400kb and damn, they still looked huge. lol
geposted Sun 17 Sep 06 @ 1:40 am
No problem. For blogs, sizes up to 500×500 (640×480) pixels are probably enough, for best file size/quality ratio use .jpg encoding with medium quality settings (easily set with software such as Photoshop, Paint Shop Pro, etc.), or try some freeware image converting software.
Regards.
geposted Sun 17 Sep 06 @ 10:34 am
