to all you vdj experts i was wondering could i use tccds with these two soundcards. 1. the hercules mk1 and 2 soundblastser live usb and use them with an external mixer(ttm57sl). one more thing, can i now use the 57sl with vdj since they came out with the asio driver for windows. i could try it myself but im on vaction and away from my system
geposted Wed 20 Sep 06 @ 11:55 pm
yes you can.. :)
(Almost) All asio soundcards will work, and it needs two line ins, and two line outs.
The performance will be a result of the asio drivers and the hardware inside the card.
That goes to latency.
So some cards will be better than others.
The MK2 has ok latency for beatmixing and basic scratch... But for super uzi hiphop scrathin, it will not sound too good.
I havent tested the other cards, but if they run in asio mode, and have enough outputs and inputs, they should work too :)
geposted Thu 21 Sep 06 @ 12:34 am
