guys pls help i installed maya44 card and setup my vdj.....while playing about half an hour its start to distrort..very bad saound...i have to reset at maya screen factory default..then it goes back normal again...The other thing is i can install vdj4.)..pls pls pls pls help guys.
dj gyanib
dj gyanib
geposted Fri 22 Sep 06 @ 12:13 pm
What VDJ version do you use 3.4 or 4? Have you installed the latest Maya drivers? What setting do you have for the "auto gain" in the config menu? If the gain is set too high distortion will occur.
Ewout
Ewout
geposted Sun 24 Sep 06 @ 9:34 pm
I agree - look at you gain settings and get the latest drivers - I did and everything works fine.
geposted Mon 25 Sep 06 @ 2:21 am
