Hey Dj's howz it going?
Ok i need some serious help -
my intentions - hooking up a mixer to my laptop to be used with VDJ - 2 channel just like the vdj mixer with pretty much the same functions. It's like this i will load the songs n everything using my trusty mouse n play the software using my mouse as well just the mixer will b hardware controlled.
Wat mixer should i buy ? Dont have alot of money to spend.
Thanks
tj
Thanks
tj
geposted Sun 24 Sep 06 @ 9:46 am
Cheap and good is Behringer VMX200, it is around 100$. You will need sound card with at least 4 channels to connect it to the mixer and VDJ Pro.
geposted Sun 24 Sep 06 @ 10:37 am
