After i scan some videos and try to close VDJ it just hangs and wont close. I have to force it to end task. Then the database isnt upadated. Anyone else having the same problem?
Thanks
Mike D
Thanks
Mike D
geposted Sun 24 Sep 06 @ 8:20 pm
create a shortcut for saving the database before the program closes , and you might wanna check how those videos are encoded
geposted Sun 24 Sep 06 @ 8:35 pm
