I get sick of my old laptop which is too slow and completely unusable with vdj 4.0.
I even have esi u46dj soundcard but it works only in WDM-mode (skipping otherwise).
That's why now i''m searching for a cheap laptop for VDJ to work with best performance and low latency ASIO mode. Maybe i'm going to use videos too.
I just came across with Zepto Znoter 6214W laptop. Zepto is a quite unknown danish computer brand. What do you think of its specs?:
Brand Zepto (from denmark!)
Product name Znote 6214W
Processor - Type Intel Core Duo T2400
Processor - Clock frequency 1.83 GHz
Processor - Frontside bus 667 MHz
Chipset - North bridge Intel 945PM
Chipset - South bridge Intel ICH7M
Memory 2048 MB
Memory type DDR2-667
SODIMM slots 2
Available SODIMM slots 0
Graphics chip nVidia GeForce Go 7600
Video memory - Capacity 512 MB
Video memory - Shared / Discrete Discrete
Screen - Size 14 inch
Screen - Resolution 1280x768
Screen - Aspect ratio 16:9
TV output Yes
DVI output No
VGA output Yes
Hard disk - Type Hitachi TravelStar 7K100
Hard disk - Capacity 100 GB
Hard disk - Rotation speed 7200 rpm
Optical drive - Type Sony DVD RW DW-A78A
Modem Yes
Bluetooth Yes
Infrared Yes
Codec chip Realtek HD Audio
Codec type HDA
Channels 7.1
4 x USB 2.0 ports, 1 x Firewire
Could it work smoothly with videos? This laptop has got relatively bad reviews
because of small screen, unconfortable keyboard and low battery life but that's not a problem for VDJ users?
It's MUCH cheaper than any other core duo laptops i found....
Memory 2048 MB
SODIMM slots 2
TV output Yes
DVI output No
VGA output Yes
Modem Yes
Bluetooth Yes
Infrared Yes
Codec type HDA
Channels 7.1
geposted Sun 24 Sep 06 @ 9:47 pm
Could work but if video is sharing memory than maybe will not work that good, you have to try it with VDJ because when graphic card share memory it is slower.
geposted Mon 25 Sep 06 @ 12:01 am
Thanks for info ALF. Specs says the video memory is discrete so no problem with it? I already ordered it, so I will recieve whole package in 2 days. It will be exciting.... :)
geposted Mon 25 Sep 06 @ 7:53 am
kool
geposted Mon 25 Sep 06 @ 10:16 am
Should work, I would like to see 7600Gt graphic on it (Go is mobile version for power saving) but you will get it anyway so we will see how it perform :) Specs are very good, good CPU and enough RAM memory for video use.
geposted Mon 25 Sep 06 @ 3:10 pm
That machine is getting SO much credit throughout the web. I live in Denmark where it´s produced and it´s a real export succes story. Personally I would have thrown in the extra cash for a Core Duo 2, 2GHz CPU with 4MB cahce and opted for the cheapest 40 GB disk - they use Hitachi which are cheap and crap. I would then have taken out that 40 GB shitkicker disk and installed a Seagate Momentus 5400.3 S-ATA disk instead. They draw power like 4.200 RPM disks and perform very very close to 7.200 RPM disks while producing almost no heat or noise.
Besides from the Hitachi disk, you get a very fine machine for your money. Congrats!
geposted Mon 25 Sep 06 @ 11:48 pm
Thanks guys for the comments!
Besides the cheap price (~1270 euros + VAT in my country) they give me better processor for free (2.0Ghz)! Woohoo! Can't wait for it! I have next gig on friday :)
geposted Tue 26 Sep 06 @ 12:20 am
