Hi i use VIRUTALDJ HOME EDITION and deck A seems to be louder than Deck B, what could be the problem and how can i fix it?
geposted Thu 28 Sep 06 @ 8:29 am
You means on HEADPHONES, on OUTPUT, ???
geposted Thu 28 Sep 06 @ 8:42 am
If you mean playing out of the speakers, go to setting, then options and set your auto gain to always 0. See if that helps. If not you will have to be more specific of what you use. ASIO? Check your settings in control panel. I've had one output higher than another. This would only happen with an external mixer and certain settings though. If you are just running out of a laptop's headphone jack yo should not hear a difference.
geposted Thu 28 Sep 06 @ 1:48 pm
Check your sound card settings and verify that your pre-listen output is not going to the same place as the main output.
I had played around with my settings not long ago and accidentally left it this way, and almost pulled my hair out trying to find why I was getting strange sound level behavior when switching decks, crossfading, automixing, etc.
geposted Thu 28 Sep 06 @ 4:40 pm
check ur sound card m8
geposted Thu 28 Sep 06 @ 7:57 pm
ok thanks all for your help, ill se if i can fix it now
geposted Fri 29 Sep 06 @ 2:37 am
Everythings perfect in the options menu, and A Louder Than B
What else can i do/try
geposted Tue 03 Oct 06 @ 5:05 pm
