hi before i fade in the track you can already hear it coming through before i even have started to fade it across which is ruining my mixes as when i'm getting the bpm matching you can hear the song. i have tried messing with the sound config but i cant sort it out.
please help
cheers
paul
please help
cheers
paul
geposted Sun 01 Oct 06 @ 3:44 pm
In Atomix Mp3? I don't remember, if you have crossfade option put it on "Full", maybe it's set on "Smooth" now.
geposted Sun 01 Oct 06 @ 5:39 pm
Don't use the cross fader. Leave it set in the middle and use your deck volume controls. I do not know what type of mixing you are doing, but the way I just described it will work for about 95% of all mixes.
Keep the beat sweet.
geposted Tue 03 Oct 06 @ 10:14 am
