How do I get the video to show on the main screen without seeing the mixer and playlist.
i looked in the video option all it shows is the window option.
geposted Wed 04 Oct 06 @ 9:32 pm
First of all, buy the full version.
Secondly, on most laptops, you can get an "Extended Desktop" option - you select that. Once you go to Config or Set (depending on the skin), it offers an additional monitor. Click on that and it puts video or visualisations on the big screen. Doesn't work on the "cracked" version you buy in Argos - the best you can do is to drag-and-drop the window to the centre of the second monitor and use the Zoom function - picture's blurry, though.
geposted Thu 05 Oct 06 @ 4:40 pm
u can do it on the demo which is full product for 20 days
geposted Thu 05 Oct 06 @ 10:22 pm
You will need a dual output video card. If you had one, you would see that in the video options drop down. Both outputs have to be connected to the computer when you boot up.
geposted Thu 05 Oct 06 @ 11:23 pm
