Can I use the jog wheels to nudge the track or does it have to be used for scratching?
Thanks.
Thanks.
geposted Thu 05 Oct 06 @ 7:03 pm
It can be used for both.
geposted Thu 05 Oct 06 @ 7:06 pm
In VDJ preferences under Remote Controllers tab where you have to enable/disable DJC, zou have function for that too.
geposted Thu 05 Oct 06 @ 7:33 pm
.. and I can tell you from experience that I use the jog wheels on my HDJC mk2 almost exclusively for jog/nudge and rarely for scratching. Just make the change as Xeon states, and you will be set.
Also, I believe some skins have a switch to go between jog and scratch modes, but couldn't tell you which skins.
geposted Thu 05 Oct 06 @ 8:11 pm
Thanks guys. I am going to pick one up tonight.
geposted Thu 05 Oct 06 @ 9:25 pm
You are welcome ;) i can send you a modified skin to change this option. I modified mix station skin for VDJ 3.4.
geposted Fri 06 Oct 06 @ 5:13 pm
