How do you get rid of the beat on Virtual DJ so that you can only hear the vocals or what the srtist is singing? Please help
HELPPPPPPPPPPPPPPP
HELPPPPPPPPPPPPPPP
geposted Fri 06 Oct 06 @ 1:10 am
You can try the “vocals+” plugin, which is included with the demo. It works well with some songs.
geposted Fri 06 Oct 06 @ 9:55 am
Removing beats or vocals will work only partly in most cases. Search the forum for vocal remover. It has been discussed before. Better is to get the instrumental or acapella of the song.
Ewout
Ewout
geposted Fri 06 Oct 06 @ 6:51 pm
