Versione 4.1
New features:
Versione 4.1 rev2
Fixes:
Se avete gia scaricato la versione 4.1 e desiderate essere abilitati al download della 4.1 rev2 andate a questo indirizzo http://www.virtualdj.com/update_r2.html
New features:
- sound engine optimized
- new sound modes for 3-line mixer: 6.1 and dual 4.1+2.0
- effect engine has been rewritten
- shortcuts and skin actions for plugin selection can now take directly the plugin name: "effect_activate flanger"
- several video fx plugins can be applied at the same time
- controller mappers are now plugins from the new effect engine
- bcd2000 is now fully supported natively
- new behavior for djconsole hotcue, loop and fx buttons
- new registry options: SearchInPath, SearchInFilename, SearchInComment, SearchInTitle, SearchInArtist
- new registry option: EqInHeadphones
- new option to disable shortcuts
- when selecting an effect from drop-down, holding "CTRL" let you select a new without stopping current.
- new actions "select_effect_multi" and "video_select_fx_multi" to select without stopping current
- better behavior for novideo plugin
- better behavior when same audio plugin applied on both decks
- new query: Query("help",char**) return a pointer to a string with the list of all query available in this version.
- new queries: angle, status, songstatus
- new action: reloop
- auto-bpm is now auto-PitchMatch, and doesn't affect "sync", but only the pitch on load (and on sync_nocbg).
Versione 4.1 rev2
Fixes:
- bcd2000 fixed (buttons up/down state was inverted, messing with cue_stop)
- headphones fixed for djconsole
- dac2 pitch fixed
- fixed "asio error" on djc mk2
- transition activation from effect page fixed
- new crossfader mode: disabled
geposted Mon 09 Oct 06 @ 8:34 am
@bcd2000 user:
il bcd2000 come potete vedere ora e' supportato nativo.
La mappatura dei tasti non e' ancora ottimizzata al 100%, comunque questo e' un punto di partenza....presto sarà ottimizzata anche la mappatura.
geposted Mon 09 Oct 06 @ 8:48 am
Salve a tutti,
prima di scaricare l'update della 4.1 avrei una domanda da fare:
Le skin della 4.0 sono tutte compatibili con la 4.1?
La risposta dovrebbe essere "si", ma mi date la conferma?
Grazie
Ciao
Grazie
Ciao
geposted Mon 09 Oct 06 @ 10:22 am
@alessandro di Pardo
per quanto riguarda le skin non dovrebbe esserci problemi...escluderei la incompatibilità....eventualmente alcune potrebbero essere aggiornate per sfruttare le nuove action..
geposted Mon 09 Oct 06 @ 10:38 am
Provo subito,
grazie Max!
Bye
grazie Max!
Bye
geposted Mon 09 Oct 06 @ 11:13 am
Fantastico...ho scaricato e installato l' aggiornamento...vediamo cosa si può configurare al meglio delle mie possibilità...rispetto a prima...noto che ci sono un bel po di innovazioni...
Grazie Team e Moderatori
Thanks Team and Moderators
DjRudy78 DiJ :-)
DjRudy78 DiJ :-)
geposted Mon 09 Oct 06 @ 12:11 pm
ricordo che nella cartella principale dell'installazione virtualdj 4.1 trovate le 35 pagine in pdf del manuale in inglese ...
geposted Mon 09 Oct 06 @ 1:56 pm
Ma si può scaricare una trial della 4.1?
geposted Mon 09 Oct 06 @ 2:21 pm
R:sara' disponibile al più presto.
geposted Mon 09 Oct 06 @ 5:12 pm
Ho provato a scaricare l'update della 4.1, ma mi si dice che ho bisogno dell'installazione completa...
ho quindi contattato l'assistenza, per vedere come posso risolvere,
a nessun altro ha dato questo problema?
e come mai?
Ciao
e come mai?
Ciao
geposted Mon 09 Oct 06 @ 5:27 pm
No l'update si è installato come tutti gli altri update..
ma qua permangono sempre gli stessi problemi..moramaxxxxxxx auiutoooo
Verificato:
directx
Usb non è condivisa con nulla
software avg antivirus ( a detta di Zio spa non rompe i maroni )
usato anche ccleaner
registro mi pare a posto
un dubbio solo..ma la finestrella che si apre quando si accende la bcd ( panel control )
non c'è verso di eliminarla?
perche' avrei voluto disinstallarla e reinstallarla..non si sa mai
Verificato:
directx
geposted Mon 09 Oct 06 @ 7:10 pm
Sulla Hercules MK2 non funziona il preascolto della tracce con il selettore sul deck A o B con la console settata in WDM, funzionano solo le modalità Mix e Split.
Se la mettete in ASIO è tutto ok, seguite il mio tutorial http://www.virtualdj.com/blog/cioce/?category=2
geposted Mon 09 Oct 06 @ 7:39 pm
ramirezdj il control panel del bcd nel devi eliminarlo!
comunque trasferiamo il nostro discorso nel topi deol bcd2000.....per rimanere in tema....
il prossimo messaggio ti chiedo cortesemente di scriverlo li, cioce non vede l' ora di moderarmi!! hi hi hih hi....
ti ho postato un messaggio qui: http://www.virtualdj.com/forums/43174/Italian_Forum/Behringer_BCD2000__(Topic_generale).html
geposted Mon 09 Oct 06 @ 7:56 pm
Ho rifatto un bel paccone con 78 effetti video Sonique funzionanti e testati su Virtual DJ 4.0 e 4.1, i due vecchi pacchetti contenevano alcuni effetti non funzionanti.
http://www.virtualdj.com/addons/view.html?type=video%20effect
geposted Tue 10 Oct 06 @ 12:29 pm
dall'aggiornamento 4.0 non riesco a scaricare l' aggiornamento alla vers. 4.1
geposted Tue 10 Oct 06 @ 2:20 pm
@robertomuiesan
cortesemente potresti registrare il tuo serial number quì:
http://www.virtualdj.com/fusers/modifuser.html
geposted Tue 10 Oct 06 @ 2:46 pm
Il nuovo Registry tool di DJcel è ora disponibile e compatibile con la versione 4.1: http://www.virtualdj.com/addons/download.html?addon_id=2170
![](http://www.virtualdj.com/blog/cioce/image5.jpg)
geposted Tue 10 Oct 06 @ 3:47 pm
uhm...
notevolemente migliorato!
continuo a dire che questa tool è fantastica e molto utile.
ciao e grazie a dj cel!
geposted Tue 10 Oct 06 @ 8:37 pm
Hmmm... adesso oltre al flanger devo riscrivermi anche il mapper e i file di intestazione... vabbé speriamo che ne valga la pena!
geposted Tue 10 Oct 06 @ 9:42 pm
Trovata la soluzione per utilizzare la console MK2 in WDM http://www.virtualdj.com/blog/cioce/?category=2
geposted Tue 10 Oct 06 @ 11:30 pm
