Forum: Old versions
Topic: Recording into waves
This question was probably already asked but I cant seem to find the correct forum. The question is how to record VDJ into wave format? The older 1.00 versions would record into wave format by default but for some reason this is not the case for version 2.00? Furthermore the older VDJ 1.00 versions would give you the option to name your file that you saved unlike version 2 which just copies over the same file name. Thanking you in advance for your help.
geposted Sun 18 Jul 04 @ 12:13 am
Go to: "config" / plugins, and disable the MP3 encoder
Thank you Coyote for your help and quick reply.
cheers
if you click the path/name of the file right above the record button, you can change the filename.
Ok that works great thank you!!
