Forum: Old versions
Topic: What exactly is x-session????
geposted Fri 13 Oct 06 @ 6:09 pm
phillydjPRO InfinityModeratorMember since 2004
Sounds like its an MK2 without a soundcard you should be able to prelisten with 4.1 or above card
geposted Fri 13 Oct 06 @ 6:42 pm
cstollPRO InfinityMember since 2004
The X-session is a simple midi controller that can be programmed to controller various items in software like VirtualDJ. It is just a midi controller.
geposted Fri 13 Oct 06 @ 10:13 pm
mp3jrickPRO InfinityHonorary MemberMember since 2003
Specifically it can be set to controll every feature on the interface.
I have mine set to control A & B volume, main volume, gain on each, LMH Eq on each, headphone mix and volume and I use the buttons for pitch reset, bass kill, and some effect plug in activation.
So it becomes the mixer essentially and then some.
Couple it up with a DAC 3 and you have all the control you could want.
geposted Fri 13 Oct 06 @ 10:36 pm
do u think that it is good as a stand alone mixer or not?
geposted Sat 14 Oct 06 @ 1:59 am
That is what I use, but remember you need a mic input and phone output which means a sound card that can handle that.
My answer was the M Audio Fast Track Pro which has twin mic inputs and a phone mixer.
However if you scratch you will need the U46DJ which has twin imputs.
geposted Sat 14 Oct 06 @ 3:34 am
