HI,
I would like to know if a keyboard shortcut can be made for the following.
Sometimes when I am running the sonique visuals in slideshow mode during music, there is 1 that I like a lot and want it to stay. So I take off (uncheck) slideshow in effects and it stays on the 1 sonique.
Can I make a shortcut for this that allows me to turn on and off the slideshow feature that runs through the different soniques?
Thanks for any detailed response.
B
B
geposted Fri 13 Oct 06 @ 6:10 pm
You should not be running the visuals through the slideshow! (not to say that you can't). It should run as it's own plugin and you just select the effect you want and it always comes on. I have not heard of running it through the slideshow. very interesting
Rusty
Rusty
geposted Fri 13 Oct 06 @ 6:48 pm
The new effects engine allows you to run multiple video effects, so it isn't a problem
geposted Fri 13 Oct 06 @ 6:51 pm
how is it done? i'm curious bout this as well
geposted Sat 14 Oct 06 @ 9:08 am
