I have read all of the threads on how to tweek your computer seetings.
No matter what I do BCD freezes after about 3 mins of playing.
I think I might go ahead and put it in storage.
geposted Fri 13 Oct 06 @ 9:23 pm
I'll post a full guide tomorrow...
But in short now:
- The BCD2000 asio drivers will freeze if it runs out of audio buffer data (this is Behringers fault)
Other soundcards will give a pop/crackle if this happens, but BCD2000 will just freeze/lock.
So, what you need to do is set higher buffer.
In VDJ performance tab, move slider to FASTEST.
Then choose AUTO for latency.
Open B-DJ control pannel, and increase the buffer, until it dont freeze.
I'll post a guide tomorrow, on how to get a better performance.
If it still freeze when setting highest possible buffer, you have an IRQ conflict at your USB port.
To free this:
- Disable WiFi
- Disable BlueTooth
(both recommended by Behringer)
+ any other hardware that you dont really need while mixing.
Also, note... Some have reported problems with certain motherboard chipsets, and Behringer have acknowledged this by an updated driver (Intel Chipset). Please make sure you have this latest driver.
Hope that help some...
geposted Fri 13 Oct 06 @ 9:32 pm
