Forum: VirtualDJ Skins
Topic: DJJB Advanced Default Video Pro
http://www.virtualdj.com/addons/skin.html?id=617
For those of you waiting for the DAC2 and the HDJC mappers to be compleletd, you should try out DJJBs excellent skin (link posted above).
It has all the right buttons and information needed to run a set until your hardware comes back online and even then you may want to keep using it.
This skin is a gem, DJJB you should update it with the new black colors.
geposted Sun 15 Oct 06 @ 3:39 am
i'll give it a try.
