So which compiler (or other SW) do I need in order to make use of this script?
Thanks
Thanks
geposted Wed 07 Sep 05 @ 1:45 pm
Jim, you need the one mentioned in previous post: http://www.activestate.com/Products/Download/Download.plex?id=ActivePerl
geposted Wed 07 Sep 05 @ 3:33 pm
Ah yes... :) I must have missed that post. Thanks.
Also:
Will this converter work with widescreen-skins? (eg 1280*800 to 1920*1200 - multiply every height, width, and all coordinates by 1.5)
- Jim
Also:
- Jim
geposted Wed 07 Sep 05 @ 4:00 pm
Hey Jim,
Do you plan on making any updates to your JN-Black skin for v3.1.1? Only thing needed really is a FX button and slider for video. If not, I was planning on adding those componenets myself if you don't mind. That skin is definitely my favorite... thanks for making it.
-Frd
-Frd
geposted Wed 07 Sep 05 @ 8:18 pm
frd1963:
It didn't require a lot of work, so I submitted an update yesterday.
geposted Sat 10 Sep 05 @ 8:24 pm
Thanks Jim. You can be sure I will be downloading it once it becomes available.
geposted Sun 11 Sep 05 @ 9:17 am
You're welcome! :)
I found a bug in the skin I submitted the other day, so I thought I'd make some more changes since I had to fix the bug anyway. I just added video-pannels. Now each player has its own video-screen.
Where Scratch On/Off used to be, you'll now find 3 buttons for the modes; normal, scratch, and video.
I hope it comes in handy...
- Jim
- Jim
geposted Sun 11 Sep 05 @ 8:29 pm
hi. can summon please upload that gr8 converter again please?
thanks in advance :)
geposted Sun 26 Feb 06 @ 12:42 am
