Well, I have 2 configurations that I use alternatively and I can't use 4.1 with either one :
1) DAC 2 + Numark USB mixer + Laptop
2) 2 Pioneer CDJ-1000 Mk 2 with TCCD + Maya 44 USB + Eclair Nuo 4 mixer + Laptop
On config. #1, no way to get the DAC 2 to work...
On config. #2, no way to get the Nuo 4 MIDI to work...
Also, would it be too much to ask from the VDJ development team to stop changing certain functions from one update to another ? Before 4.0, the match key on the DAC 2 would start the track and sync it, now 2 steps are necessary to do that... We use a certain function for months and months and all of a sudden we get a different behavior for that same function, what a pain in the rear end...
geposted Tue 17 Oct 06 @ 2:16 am
DAC 2 needs new mapper I think and Ecler is not working properly in V4.x but will be fixed.
geposted Tue 17 Oct 06 @ 11:55 am
Yes all mappers need to be re-written for 4.1
geposted Tue 17 Oct 06 @ 5:51 pm
Dac 2 fix in 4.1 revision 2. Contact dev for a link
geposted Tue 17 Oct 06 @ 6:11 pm
