Forum: Old versions
Topic: CDJ and VDJTime Code PROBLEM ! ! !
ripeiroHome userMember since 2005
i use de vdj whit timecode and cdj but when play the 4 or 5 music the virtual dj lose the contact whit the cdj, i stop the cd and the music continious play ....
help me!!!!
geposted Tue 17 Oct 06 @ 9:02 pm
phillydjPRO InfinityModeratorMember since 2004
what version are you running? sounds typical of an unofficial version why not just enter your serial and download the latest copy
geposted Tue 17 Oct 06 @ 11:11 pm
i download the latest copy...
geposted Wed 18 Oct 06 @ 2:08 am
I did all test with other versions and all make problem in the 4 or 5 i stop the cd and the music continus playing i use ASIO4ALL emulator, PC 3.0 , 512m.
plugged my cdj into Sound blaster 7.0 Sound card:
line-in: cdj
output: mix
output: mix
the soundcard of my PC:
line-in: cdj
geposted Wed 18 Oct 06 @ 2:21 am
The timecode signal is too loud into your PC, because Pioneer CDJ's play really loud.
Find the level slider at your Soundcard control pannel, and lower the line in volume (record setting).
If thats not possible, open the timecode mp3 file in a wave editor, and lower the volume about 12db.
Then save it as as new wavefile, and burn to new timecode cd...
That way it should work great ;)
geposted Wed 18 Oct 06 @ 8:14 am
