Forum: VirtualDJ Skins
Topic: Taskbar in skins
I am a PCDJ FX user that has slowly made the transition to Virtual and I love the program for the most part. My question is that in all the VDJ skins the windows taskbar is hidden. In my skins for PCDJ the taskbar is always visible, I am assuming the skin makers just built the skins a little smaller to always see the taskbar. Is it possible to have skins done like this for VDJ or is that asking alot. I just always like to see the taskbar, if I have a problem it is easier to figure out what it going on.
Just a suggestion, maybe other people might feel the same, maybe not.
Thanks,
Chris
geposted Wed 18 Oct 06 @ 12:49 am
Taskbar ?
If you mean the different "pannels" in the music browser, they can be locked at any position...
Press the Lock button on each pannel...
No, the issue is trimming the bottom of the skin just short of taking the whole screen. This way one can still access the start button of the Windows task bar.
just minimize or de-max vdj and there is the startbutton
I think You Mean the Restore Button, Its the one in the middle
Then you can see the taskbar and also move the skins around
yep restore, my english is not that good.
you have to set vdj to restore. because if you resise a skin to 1024-750 and set this to max the skin will fit in the screen. than you still can't see the browser.
and you always have the startbutton on your keypad.
What I mean is what CSTOLL had put in the thread. I would like to trim the size a little shorter so that the entire taskbar is visible all of the time.
Just a suggestion or wish.
Chris
that isnt so hard, just edit the xml and shorten the height of the skin from 1024x768 to 1024x738
also shorten your browser by 30
BTW u might have to play around with the amount u decide to shorten it, but make sure whatever u takeway from the skin size you also take away from the browser
