hi all,
i have been trying to map various function of vdj onto ecler nuo4 midi outputs. I seem to have found some sort of error. When i configure one of the dials on nuo4 to scroll through the effects, when it gets to beatgrid it freezes vdj and i have to control alt delete to shut vdj down. Strangely it only happens on deck 1, on deck 2 it scrolls perfectly.I have check there are no midi channel contradictions. I have configured the dial on nuo4 to be midi note on/off in both directions, and in vdj i select +1 in value for one direction only. Would appreciate any suggestions,
thanks stefdj.
thanks stefdj.
geposted Wed 18 Oct 06 @ 8:42 am
Can you try this:
http://www.virtualdj.com/addons/download.html?addon_id=2511
and see if it helps?
Regards
Regards
geposted Wed 18 Oct 06 @ 9:21 am
thanks dj-alf, but i have already downloaded the nu04 plugin, i am now just altering it to suit my needs. One of which is being able to shuffle through the effects by using just one dial then pushing to activate that effect. I have managed to achieve this on deck 2 but as i said before on deck 1 it crashes when you cycle past beatgrid.
geposted Wed 18 Oct 06 @ 8:47 pm
