With home edition you can use time code CDs or Vinils for only 5 minutes http://www.virtualdj.com/products/djcedition.html
geposted Fri 12 Jan 07 @ 10:27 am
sirmix123 wrote :
can i use timecoded cds on v3.4 i just got the program
yes for a 5 minute test period
to use it properly you need pro
as you bought mk2 your are entited to a discount
geposted Fri 12 Jan 07 @ 11:44 am
now i can't get 100% signal i get no signal and i press auto congfig ad it says that it can't be found check ur cables and try again wat am i supposed to do now????
geposted Wed 17 Jan 07 @ 11:29 pm
ok lets chat about what you have done
are you using 3.4 or 4.2?
have you grounded your cables?
have you choosen autolatency on the proformance tab?
what needles do you have?
geposted Wed 17 Jan 07 @ 11:34 pm
im using 3.4 wat do u mean grounded my cables and i can't find the autolatency on the performance tab and i use timecoded cds
geposted Wed 17 Jan 07 @ 11:42 pm
alright , you are limited to 5 minutes of timecode to demo it .
if your cd players alow you to ground the connections link the grounding posts from mk2 to decks
now the problem is that every cd player has a different native gain if the waveform is very large
it is because the cds are to loud , if they are to small they are to quiet
if they are to loud try boosting the cd in steps , of say 5 db
and if to loud lower in steps of 5 db
using a program such as audcacity
http://audacity.sourceforge.net/
burn a copy of the disk at each level and try until you find the one at the right level :)
burn another copy of the right level your good to go
now ul need to update to pro but as you bought the mk2 your entitled to a
discount
discount
geposted Wed 17 Jan 07 @ 11:47 pm
this is dj rick lee how do i sign up for the radio
geposted Wed 17 Jan 07 @ 11:53 pm
you need to buy pro , to be able to apply
geposted Thu 18 Jan 07 @ 9:46 am
i just got my tcv don't like tccd does it work the same and how long can i use the tcv for
geposted Mon 22 Jan 07 @ 1:08 am
works just the same way except you need to choose vinyl instead of cd
its still 5 minute limit for home users why not upgrade if you like it you are entitled to a
discount
discount
geposted Mon 22 Jan 07 @ 5:51 pm
i have 3.4 full version with everything
geposted Mon 22 Jan 07 @ 7:03 pm
then please add your serial
http://www.virtualdj.com/fusers/modifuser.html
for pro edition
for pro edition
geposted Mon 22 Jan 07 @ 8:07 pm
i have had virtual dj since 3.4 came out but i lost my cd key
geposted Mon 22 Jan 07 @ 10:29 pm
mmm then contact support
contact
be aware the edition that comes with the console is 3.4 and is not a pro copy
contact
geposted Mon 22 Jan 07 @ 10:56 pm
Two questions:
1- Can somebody please either explain, or point me to a place that explains exactly what time code vinyl is, what it does, how it can be used, and why I'd want to use it? I know nothing about it, but see it all over the place. I don't use turn tables, but do have a DAC3, and a MK2, along with a Maya44 internal sound card. Pro user.
2- I see many users have the mk2 icon under their name. How do I get that under mine? I went to update my account, but didn't see how to add it.
geposted Wed 24 Jan 07 @ 5:14 pm
![](http://www.virtualdj.com/blog/dams/image3.jpg)
choose dual timecode and
choose asio card
Select the 'Maya44 USBAudio ASIO Driver' in the drop down
-Click on the ASIO Config... button
---USB Tab - Device Maya44, checks in Output and Input, Sample Rate - 44.1kHz, Resolution 16bit
---ASIO Tab - ASIO Resolution 24 bit, System performance - Highspeed, everything else default
---Controls Tab - Same as Line 2 above.
---Close
-Config Timecode left and right (my settings are identical)
---Gain is about 15-20% from left
---Silence is the same as Gain
---Now I use the Vinyl so here are where things get different -
-----Vinyl Users - check in Software RIAA
-----CD Users - Software RIAA usually not necessary
-----Invert Stereo or Phase checked if you plugged things in backwards.
-----Turntable - obvious choices
geposted Wed 24 Jan 07 @ 5:26 pm
for the pci version of the card
same thing applys just choose "maya 44 pci " instead :)
as to your mk2
add the serial number from the slip with the install disk in it :)
here
as to your mk2
here
geposted Wed 24 Jan 07 @ 5:28 pm
OK, I understand how to set it up, but what exactly does it do? What is tcv for? If I run only mp3/mpg, is it pointless?
Now I know how to install my MK2 icon! Thank you for that.
geposted Wed 24 Jan 07 @ 5:55 pm
timecoded vinyl is a special vinyl with code on it
it makes the software act like a real vinyl would when you take an action
ie speed it up , so does the software , backspin , so does the software
stratch so does the software exactly like you did it .
you can choose the modes you want ie software help to sratch
or no help for the hardcore turnablist :)
i use it with mp3 and video alot :)
geposted Wed 24 Jan 07 @ 6:03 pm
that's a very nice guide. thanks a lot but i have a question. is it possible to connect both 2 turntables and 2 cd players on mk2 and on a 2ch mixer?if yes how could be done.
a pic sould be nice.
geposted Fri 02 Feb 07 @ 8:04 pm
