Forum: Old versions
Topic: command similar to xp10 touch surface
alx2kPRO InfinityMember since 2004
I was thinking to do some modifications on my old mk1, and then, if working good, maybe translate them to my mk2.
the proyect would consist of a metallic touch sensitive switch, an USB keyboard and home made metallic circles.
I want to glue them on top on mk1 scratch weels, conect them to the touch sensor inside, and the touch sensor would be asigned to a key stroke on the USB keyboard.
All that stuff would likely work... but I need a command to be asigned to that keystroke. I found "play_stutter" but is there a more convinient one?
Thanks in advance.
geposted Wed 18 Oct 06 @ 5:21 pm
