I'm using 4.1 it looks like everything is runnig fine the only thing is that when I load a video into either deck the video output freezes for a split second then everything is fine .Then again when I load another song the same thing.Any help on fixing it?My specs are dual core 1.83,2 gig of memory,ati1600x w/256 of memory using vmix as the skin.
geposted Thu 19 Oct 06 @ 10:21 pm
Hmm, my new system is doing the same thing, so when i figure it out I'll get at ya
even worst when i use the svideo to hdtv adapter
geposted Fri 20 Oct 06 @ 12:54 am
Does the video freeze on your monitor or on the output? (Or both?)
Do you have a video card for the output?
Have you optimized your setup for performance?
Though I'm not entirely sure about specs, I think your processor is a little on the weak side. I'm running a 3.4 with 4GB memory and 1 GB video card and haven't had a single problem. The vids load up and play flawlessly.
geposted Fri 20 Oct 06 @ 6:11 am
What controller are you using? Thats if your using one.
If your using a hercules mk 1 / mk 2 I would advise buying a powered usb hub.
This solves alot of problems using these controllers.
Everytime i loaded a music video or even a normal mp3 the screen would freeze a split second or even skip the music.
Powered usb hubs solve these problems.
Thats if ure using a hercules controller that is.
geposted Sun 22 Oct 06 @ 5:58 pm
I'm using dac3.I though the laptop was more than enough to do videos.The video card is ati1600x with 256mb of memory.So what can I do?
geposted Tue 24 Oct 06 @ 11:57 pm
Can anyony figure this out?
geposted Thu 26 Oct 06 @ 12:09 am
actually i noticed it does not happen on VOB files
geposted Thu 26 Oct 06 @ 5:31 pm
