Forum: Old versions
Topic: Visuals in 4.1 question
Are there visuals in this verson? I mean visuals that work with audio only files? I see a check box that says "use this plugin for audio-only files" but the only plugins are for "Video". Can I add winamp plugins for audio in the "plugin folder?
geposted Fri 20 Oct 06 @ 8:09 am
geposted Fri 20 Oct 06 @ 8:13 am
i downloaded the plugin but i cant seem to get it to work, the instructions are not clear, where do you put the plugin?
geposted Fri 20 Oct 06 @ 9:48 am
geposted Fri 20 Oct 06 @ 12:28 pm
