Forum: Old versions
Topic: almost there!
junjunHome userMember since 2006
Hi guys,
so i finally managed to track down a maya 44 off of ebay =D
so i think all i need to do is purchase the TCVs and the pro version of virtual dj, correct?
which brings me to my last question, when i go to the purchase screen, i see a virtual dj for $299, as well as one for $319? the latter on a picture link on the bottom on the screen, they both say pro on them, so i'm a little confused as to which one i need to purchase?
Cheers!
geposted Sat 21 Oct 06 @ 12:04 pm
One is a digital download and no boxes will be sent to you. that's the 299 one.
The other is the box set. You'll have a compact disc with the software on it and the manual. That's the 319 one.
Hope this helped.
Karlo.
geposted Sat 21 Oct 06 @ 1:57 pm
rEsKPRO InfinityMember since 2006
Yes, and both are the same version
geposted Mon 23 Oct 06 @ 11:19 am
mainedjPRO InfinityMember since 2006
So you could you buy the $299 one and just burn the fownload to a disc, write the key on the disc and there must be a product manual somewhere on the VDJ site that could be printed or saved...?
geposted Tue 24 Oct 06 @ 1:12 am
