I was looking at the Numark CUE software, and discovered the upcoming Numark Virtual Vinyl software/hardware.
I am assuming that it like Serato in not needing a seperate sound card, but that the software is actually like Virtual DJ. I have a M-Audio Fast Track Pro on order along with a Dell e1505 laptop. The Fast track pro order can be canceled though.
It comes with the time coded records as well as the cd's (which I would use 97% of the time).
I was going to purchase virtual DJ today, and after reading different bits about Virtual Vinyl, I am thinking that I am going to be getting the best of both worlds, for about the same price.
What do all think, and what software has more advantages.
From what I have read the Virtual Vinyl is going to be $499.
Thanks in advance!
Thanks in advance!
geposted Sun 22 Oct 06 @ 6:51 pm
lol just so u know virtual vinyl is vdj with a nurmark sticker on it so u still get the goodsoftware
geposted Sun 22 Oct 06 @ 6:56 pm
Numark Virtual Vinyl: A package that includes software + soundcard + timecode vinyls
- Numark Cue
- timecoded vinyls branded with Numark lgoo
- Soundcard branded with Numark logo
The software is the same as Virtual DJ.
You can of course get Virtual DJ , and use the card you ordered too.
And then get timecode vinyls from here (branded with VDJ logo)
Or get the full package from Numark ;)
- Numark Cue
geposted Sun 22 Oct 06 @ 7:00 pm
Wouldn't the interface that comes with the Virtual Vinyl be better suited, or would it matter?
geposted Sun 22 Oct 06 @ 7:04 pm
The Numark interface is tailored for the software... true :)
But good pro soundcards that run asio at low latency will peform as well..
Such as U46dj, maya44, Delta44 etc etc.
The Numark solution will no be available before another couple of months by the way
geposted Sun 22 Oct 06 @ 8:02 pm
So a M-Audio fast track pro will do the same thing then?
geposted Sun 22 Oct 06 @ 8:06 pm
I guess I need to just decide if I like the VDJ or the CUE better then...or did I read that there is a skin for VDJ just like CUE somewhere?
geposted Sun 22 Oct 06 @ 8:10 pm
http://www.virtualdj.com/addons/skins.html
Don't think there's a numark cue skin there though, but the choice is quite adequate.
geposted Sun 22 Oct 06 @ 8:14 pm
Ciao a tutti
mi chiamo Pasquale detto lino
io voglio diventere un Dj non professionista un Dj normale.
Io sono appasionato della musica mixata se io voglio sapere se lo posso fare si o no
Il programma e bello virtual Dj io fatto 12 cd mixati da me
cia a tutti
cia a tutti
geposted Sun 22 Oct 06 @ 8:37 pm
Try the demo, and you will see it has almost same skin as Numark Cue
http://www.simtel.net/product.download.mirrors.php?id=98165
Any Soundcard may work with VDJ, unless you want to use TCVs, the only M-Audio available for TCVs use are the Delta Series and M-Audio 1814 Firewire. You can use M-Audio Delta 44 or 66 or 1010LT or Firewire 1814, also Terratec 88 or even a Creative X-Fi Platinum or Fatal1ty or Elite Pro. And of course the Esi-Pro U46DJ and others which have 2 Stereo line INputs and 2 stereo Line Outputs and works in ASIO.
The Fastrack don't have enough inputs to handle 2 Turntables.
So I'd cancel that card if I where you... ;) Get a different soundcard...
geposted Sun 22 Oct 06 @ 8:54 pm
Doesn't it have 4 inputs (2 left,2 right)???
http://www.m-audio.com/layout/imgview.php?i=/images/en/callouts/big/fasttrackpro_front-rear.jpg
geposted Sun 22 Oct 06 @ 9:51 pm
Here are the other details:
insert jack (¼” TRS) for outboard processors
2 balanced outputs (¼” TRS)
4 unbalanced outputs (RCA)
S/PDIF digital I/O with w/ 2-channel PCM
S/PDIF out also supports pass-through of AC-3/DTS surround-encoded content
1 x 1 MIDI I/O with activity LEDs
headphone output (¼” TRS) with level control
headphone A/B source switch for DJ-style cueing
input/playback mix control for hardware direct monitoring
mono switch for input/playback direct monitoring
master output level control
near zero-latency hardware direct monitoring
low-latency ASIO software monitoring
USB connection to computer
powered via USB or optional AC power adapter
Kensington lock port
Mac and PC compatible; class compliant with Mac OS X 10.3.9 and higher
* 16-bit/48kHz 2 x 4 operation is class-compliant. Driver installation required to access more I/O.
Digital Audio Interface Specifications 48kHz sampling rate unless otherwise stated
Mic Inputs (A/D)
Input Impedance 2.7k Ohms unbalanced, 5.4k Ohms balanced
Maximum Input Level from +24dBu @ min gain, pad on to -40dBu @ max gain, no pad
Channel-to-Channel Crosstalk < -110dB
SNR -101dB, A-weighted
Dynamic Range 101dB, A-weighted
THD+N 0.005% (-86dB) @ -1dBFS, 1kHz
Frequency Response 20Hz to 20kHz, +/- 0.1dB
Pre-amp Gain >40dB
Pad -20dB pad
Instrument Inputs (A/D)
Input Impedance >220k Ohm, unbalanced
Maximum Input Level From +22dBV @ min gain, pad on to -42dBV @ max gain no pad
SNR -100dB, A-weighted
Dynamic Range 100dB, A-weighted
Frequency Response 20Hz to 20kHz, +/- 0.1dB @ 48kHz sample rate
Pre-amp Gain >40dB
Pad -20dB pad
Line Inputs (A/D)
Input Impedance 20k Ohms balanced and unbalanced
Maximum Input Level +4.1dBu balanced, +1.9dBV unbalanced
20Hz to 40kHz, +/- 0.1dB @ 96kHz sample rate
Pad -20dB pad
Input Inserts (analog)
Maximum Level Send +6dBV, unbalanced
Maximum Level Return +6dBV, unbalanced
THD+N 0.00281% (-91dB) @ -1dB from max level, 1kHz
Frequency Response 20Hz to 40kHz, +/- 0.1dB
Line Outputs (D/A)
Output Impedance 150 Ohms unbalanced, 300 Ohms balanced
Maximum Output Level +1.8dBV, unbalanced
+10.1dBu, balanced
Channel-to-Channel Crosstalk < -108dB
SNR -103dB, A-weighted
Dynamic Range 103dB, A-weighted
Frequency Response 20Hz to 20kHz, +/- 0.3dB @ 48kHz sample rate
Headphone Output (D/A)
Maximum Output -2.5dBV at THD < 0.05% into 32 ohms
Working Range 32 to 600 ohms
I/O Bit Depth Sample Rate (kHz)
With Drivers 4 x 4 16 44.1/48
2 x 4 24 44.1/48
2-in OR 2-out 24 88.2/96
Class compliant 2x4 16 44.1/48
WDM
ASIO 2
Core Audio
Pentium 3 – 500 MHz (higher speed CPU may be necessary for laptops)
256MB RAM
DirectX 9.0c or higher
Windows XP* (SP2)
(Windows 2000, 98, 98SE, ME & NT not supported)
USB port
* Home and Professional Edition only. Windows Media Center Edition is not currently supported.
Macintosh G3** 600 / G4** 667MHz (higher speed may be necessary for laptops)
256MB RAM
OS X 10.3.9 / 10.4.2 (earlier versions of Mac operating systems are not supported)
USB port
Dolby AC-3 and DTS pass-through with Apple DVD player
* M-Audio suggests that you also check the minimum system requirements for your software, as they may greater than theabove.
** G3/G4 accelerator cards not supported; native FireWire ports required.
Mic Inputs (A/D)
Pre-amp Gain >40dB
Pad -20dB pad
Pre-amp Gain >40dB
Pad -20dB pad
Line Inputs (A/D)
Pad -20dB pad
Line Outputs (D/A)
+10.1dBu, balanced
2 x 4 24 44.1/48
WDM
ASIO 2
Core Audio
256MB RAM
Windows XP* (SP2)
USB port
256MB RAM
USB port
geposted Sun 22 Oct 06 @ 9:59 pm
![](http://www.m-audio.com/images/en/callouts/big/fasttrackpro_front-rear.jpg)
As far as I know, the Fast Track Pro does NOT have 2 regular RCA inputs for connecting turntables.
You can connect mic & instrument, but doubt you can use the same input for turntables.
geposted Sun 22 Oct 06 @ 10:27 pm
Get this card and you'll do great with Virtual DJ ;)
Best USB solution...
For internal cards, get Delta 44 or similar...
![](http://www.ibsenstudio.no/prod/esi/usb/u46dj/U46DJ-d.jpg)
geposted Sun 22 Oct 06 @ 10:52 pm
Exactly...
geposted Mon 23 Oct 06 @ 1:03 am
