Can anybody help with rip vinyl
I have tried the rip vinyl programme in v4.1 & 4.1r2. The programme seems to have no problem recording, but refuses to let you save anything. It always comes back with an error message that says impossible to save.
I have tried saving to a number of different drives, but always get the same error message.
I have also tried a number of different soundcards and come up with the same problem.
I noticed that a number of people in the forum have the same problem.
Aslo tried using asio & wmd same result no matter what card i use.
PS. It worked fine in v3.1
geposted Mon 23 Oct 06 @ 5:58 pm
hi have u selected the lame codec ?
geposted Mon 23 Oct 06 @ 8:50 pm
i have selected the lame codec.
The codec works with recording in vdj but not in rip vinyl.
geposted Mon 23 Oct 06 @ 9:16 pm
yah im having the same problem
geposted Sat 02 Dec 06 @ 1:11 am
have you tired saving it as a .wav?
geposted Sat 02 Dec 06 @ 11:11 am
it wont let you save it as a wav....... and it used to work before i upgraded......
geposted Sun 03 Dec 06 @ 12:08 am
so to recap you have v4.0
uv done a full reinstall and u have replaced the lame codec?
geposted Sun 03 Dec 06 @ 12:14 am
correct
geposted Sun 03 Dec 06 @ 8:05 pm
have u tried a hard reinstall ?
using regedit?
using regedit?
geposted Sun 03 Dec 06 @ 8:11 pm
yah i did and gave up im downgraded to 3.4 till this is fixed
geposted Wed 06 Dec 06 @ 12:56 am
